Activity Forums Adobe Premiere Pro Effects to whole Sequences
  • Effects to whole Sequences
    Posted by Justanotherguy on November 19, 2005 at 6:58 pm
    Within Premiere Pro 1.5, Is there a way to apply a single (or multiple) effects onto an entire sequence that is filled with a variety of media formats? That way the user won’t have to adjust the same parameters for the same effect on individual files. Thanks!
    Craig Howard replied 20 years, 10 months ago 3 Members · 3 Replies
  • Craig Howard
    November 19, 2005 at 11:57 pm
    Yes there is in fact…”nest the sequence” in a new sequence.
  • Hector Melendez
    November 21, 2005 at 5:05 am
    I have a concern with this advice, same as Timothy told me.
    I did a “nest procedure” for applying a slow motion” to a bunch of clips and everything went ok… very happy… until I burned the DVD disc. The burned disc produced a stutering or strobbing motion in the slow motion recap. I called another PP user and he told me that this is an old not resolved issue…. I’m very disapointed.
    So it looks like we have to go one by one to do this kind of task.
    Its sad that after 5 hrs to render/encoding & burning a project the final disc it’s not pleasant.
  • Craig Howard
    November 22, 2005 at 12:45 am
    Slow motion is a special case effect because it changes the length of the clip.
    In a nest the clips are all contiguous. They need to expand and make room for each other. This can cause problems even in the original timeline unless you allow “room”.
