Activity › Forums › Adobe After Effects › effects to fix fluorescent light flicker?
Posted by Happy-goe on October 3, 2006 at 6:45 pmhi- we’d like to pick people’s brains for the problem we are facing-
we received tapes shot under fluorescent light and
all the footage has flickering.
is there any effects or any way to fix this flickering or diminish flickering?
we deeply appreciate you if you could give us some advice.
i don’t know if after effects will be the answer.
we are quite open for any advice to solve this problem.
thank you so much in advance-Happy-goe replied 19 years, 11 months ago 4 Members · 9 Replies -
Erik Pontius
October 3, 2006 at 7:19 pmWhat are you editing on? There is a company called 3prong (3prong.com) that makes a Avid AVX plugin called “FlickerFix” that does a great job at reducing flicker. You apply the effect to footage, then position 3 boxes representing normal levels of bright, dark and chroma around in the frame…you set these as a reference level values and it levels out the rest of the clip to match.
Erik
Filip Vandueren
October 3, 2006 at 11:25 pmWhat you describe sounds like a variation on the ‘Color Stabilizer’ effect: this is included in After Effects.
Check the manual on how to use it.
Filip Vandueren
October 3, 2006 at 11:26 pmWhat you describe sounds like a variation on the ‘Color Stabilizer’ effect: this is included in After Effects.
Happy-goe
October 4, 2006 at 2:45 amThank you so much for your advice-
unfortunately we are editing on final cut.
but i will try to look into their web site.
i didn’t know flicker fix effects exist-
so we are glad to know that. worst case,
we have one machine installed avid. so maybe
we will try with that.
thank you again-HK
Happy-goe
October 4, 2006 at 2:49 amthank you so much for your advice-
i will try the color stabilizer.
great! i will report how it goes.
thank you so much-HK
Erik Pontius
October 4, 2006 at 5:48 amGlad to help. I once used FlickerFix to fix (at least minimize) the flicker in an interview that was shot in NTSC in Ireland in a room full of colored flourescent and halogen lighting, with several large LCD projectors, several plasma TV’s and a large number of flat panel LCD computer displays…a lethal combination.
Good luck!Erik
John Kaley
October 4, 2006 at 5:03 pmThe “Deflicker” plug-in from Tinderbox 1 has saved the day for me many times.
Happy-goe
October 5, 2006 at 5:24 pmthank you so much for your advice-
luckly, we have tinderbox and i experimented it. however,
there seems to be software problem or something
