Activity Forums Adobe After Effects effects that use comp cameras…
  • effects that use comp cameras…
    Posted by Neil Stubbings on October 6, 2006 at 2:36 pm
    how can i set their position in 3d space?
    i.E Forge Freeform. I have a flythrough camera movement and have some layers in my 3D space who use forge freeform to be distorted. but how can i set their position in 3D space? Because effects that use cameras or lights need to be applied to 2D layers
    Steve Roberts replied 19 years, 11 months ago 2 Members · 2 Replies
  • Neil Stubbings
  • Steve Roberts
    October 6, 2006 at 2:52 pm
    Any “3D effects have to be applied to 2D layers (flat to camera), because AE makes a 3D “movie” that plays on a 2D “screen”. If the layer were 3D, you’d see the flat “screen” at an angle, and the illusion would be lost.
    So effects that use a comp camera use the camera info to create the 3D movie that plays on the flat screen. It’s an illusion. If you have “comp camera” selected, the layer is seen accurately by the comp camera. However … you need to set the layer’s position within the effect. All controls for any 3D effect need to be set within the effect — the comp camera button just syncs the effect’s camera with the comp camera.
    I haven’t used FF in years … there should be position controls within the effect. However, you may be close to graduating to a real 3D app. 🙂
    Hope that makes sense …
