Activity Forums Apple Final Cut Pro Legacy effects questions
  • effects questions
    Posted by Lonnie Goodwin on November 9, 2010 at 9:44 pm
    Hello–
    I have a couple of questions. Your help would be greatly appreciated!
    1. I’m trying to rotate clips slightly to fix shots that were shot slanted, and then apply widescreen to them. What keeps happening is the widescreen is applied rotated as well. Because rotation is affected by the Motion parameters and isn’t a filter, I can’t simply change the order of filters. Is there a way to do this so that the widescreen looks fine?
    2. I am trying to crop several images and overlap them on the screen. I can’t seem to control which clip will overlap which. Is there a way to control that?
    Lonnie Goodwin
    Patrice Freymond replied 15 years, 9 months ago 3 Members · 2 Replies
  • Thomas Morter-laing
    November 9, 2010 at 10:41 pm
    Are you talking about a widescreen filter? If so one solution could be to remove the filter from the clip in question and rotate as you wish, then apply two black slugs above the clip and position and size each one accordingly, so that it blocks the same amount of the images and matches the clips on the rest of the timeline.
    Tom Morter-Laing
    Certified Apple Product Proffessional, 2010
    Degree; TV Production
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800).
  • Patrice Freymond
    November 10, 2010 at 7:40 pm
    1) Filters are always rendered before the Motion Tab parameters. Nest your rotated clip and apply filter to nest
    2) The order of your layers is the order of your tracks. Upper track = upper picture.
    These are pretty basic questions. Maybe a bit of manual reading (or the excellent Peachpit books) is warranted.
    hope this helps,
    Patrice
