Activity Forums Adobe Premiere Pro Effects Panel Window forward 1 frame
  • Effects Panel Window forward 1 frame
    Posted by Peter Lee-jones on October 19, 2016 at 9:57 pm
    Hi CC,
    Is there a keyboard key for advancing the sequence / clip 1 frame forwards whilst in the Effects Panel Window?
    I have a mask active and I want to go forward 1 frame to adjust the mask. If I use the mouse on the sequence window I lose the active vertices on the mask. Then I have to reselect the vertices and that introduces an error.
    Obviously the arrow keys move the vertices… so they don’t behave in this instance.
    The focus should be the mouse moving the vertices and the keyboard moves the sequence/clip time frame by frame.
    Any ideas?
    Pinewood Studios, UK
    Peter Lee-jones replied 9 years, 10 months ago 2 Members · 2 Replies
  • Peter Garaway
    October 19, 2016 at 10:40 pm
    Hi Peter,
    Try holding down Cmd/Alt + arrow keys
    Does that work for you?
    Peter Garaway
    Adobe
    Premiere Pro
  • Peter Lee-jones
    October 19, 2016 at 10:53 pm
    Hi Peter,
    Actually that does work! The reason it works is because I should have activated the Program Panel Window. It doesn’t work on the Effects Panel Window.
    Problem solved!
    Pete, UK
