Activity Forums Adobe Premiere Pro Effects Panel Does Not Update
  • Effects Panel Does Not Update
    Posted by Tod Hopkins on September 30, 2025 at 9:16 pm
    I’m frequently seeing the Effects control panel “stick” on a clip. I make a change to a clip in the Effects panel, then select a different clip, but the Effects panel continues to show the first clip. It does not update to show the new clip. Often I don’t realize it right away because the controls still work, but they aren’t changing the currently selected clip. The only solution is a program restart. This happened roughly half a dozen times today.
    Anyone else seeing this? Version 25 through point iterations including the current 25.5.
    Devrim Akteke
    replied 11 months ago
    2 Members · 1 Reply
  • Devrim Akteke
    October 1, 2025 at 3:41 am
    Not exactly the same one, but I have a similar problem too. Sometimes when I set my In and Out points in the timeline, it does not show the correct duration. I change the In or Out point to see if it changes, but no luck. Only after I double-click a clip or go to another sequence and come back to the one I was working on then it becomes normal. I guess this is one of those little bugs in 25.
