Activity › Forums › Adobe After Effects › Effects not interlacing right
Posted by Rick_y on August 28, 2007 at 9:13 amHello!
We have a huge problem with effects not interlacing right with the backgroundmovie.We have a PAL movie with upper field and above that a solid with trapcode stroke.
When rendering out interlaced the trapcode stroke layer gets full of lines and it looks like a interlace problem.Someone who got an answer?
Thanx!!
Kevin Camp replied 19 years, 1 month ago 3 Members · 8 Replies -
Steve Roberts
August 28, 2007 at 12:15 pmAre you scaling in the output module?
If so, you should never scale in the Output Module when rendering interlaced. You should drag the comp into the desired size comp and render that.Or is it something else?
Rick_y
August 28, 2007 at 12:22 pmHey thanx for the answer!
It’s not scaling, it’s the same size and same format as the original file just with graphics on top of it.. it’s the graphics that gets weirdlooking.
Just as it with DV-interlaced format before you deinterlace it…very weird.. !
Steve Roberts
August 28, 2007 at 12:28 pmUm … it sounds as if you’re just seeing the interlacing, which is normal. How does it look on a TV?
(and you should have one)
Rick_y
August 28, 2007 at 12:43 pmYeah maybe! Haven’t got a monitor at home.. But if the videoclip looks good.. wouldn’t the graphic look good as well?
And if I render out in no fields the videoclip looks interlaced but the graphic looks good…
hmm
Steve Roberts
August 28, 2007 at 1:02 pmWell … “good” or “bad” might not be the issue here. If the interlacing is regular (all being 1 pixel thick), then it’s an issue of “interlaced” vs. “non-interlaced”. You want the clip and the graphic to match, one way or the other.
It might be an interpretation issue. If you’re doing nothing to the clip (no scaling, moving, blurring or otherwise distorting) then field separation should be *off* for the video clip. (file>interpret footage>main)
Then you render interlaced. If nothing has been done to the footage clip AE will leave it alone — interlaced. The interlaced *rendering* only happens to something that is animated within AE, which is the graphic in this case.
The result should be an interlaced graphic over an interlaced clip.Try it.
Rick_y
August 28, 2007 at 1:31 pmYeah! That sounds perfectly logic!
I gonna look into it tonight! I get back you to this thread tonight!
Cheers! I’ll buy you a beer next time I visit your country if it works =)
Rick_y
Kevin Camp
August 28, 2007 at 1:55 pmit shouldn’t matter if the interpret footage is set to separate fields or not if you are rendering back to fields, putting fields back in will reinterlace the footage even if separate fields was set (i generally work this way). and by your mention that when you rendered w/o fields you saw interlacing in the background footage, that would indicate that you weren’t separating fields for that footage anyway.
so i think there is something else going on here… can you post a sample of the two renders?
Kevin Camp
Designer – KCPQ, KMYQ & KRCW
