Activity › Forums › VEGAS Pro › Effects in multi-camera
  • Effects in multi-camera
    Posted by Pascual Angulo on December 28, 2013 at 9:31 pm
    Hi! I’m editing a multi-camera show, recorded with two identical Canon HF-M31 HD definition cameras, and a third different camera. The point is that once I’ve created the multicamera track, the color correction needed for the 3rd cam is lost. Every time I switch to that cam, I need to manually apply the effect: color correction, with a preset made for the specific correction. (I can apply the effect to the whole event, and then select the preset,ok…) There’s a way to select all the takes of the 3rd camera and apply the effect (and the preset well) for it?
    Thanks in advance and forgive my limited use of english…I’m spanish speaker, so you can reply in spanish too, Gracias!
    John Rofrano replied 11 years, 3 months ago 4 Members · 9 Replies
  • 9 Replies
  • Mike Kujbida
    December 28, 2013 at 11:30 pm
    This was just discussed in the past two days.
    Read the replies by John Rofrano in the Process for color-correcting & stabilizing with multi-camera thread and you’ll be all set.
  • Pascual Angulo
    December 29, 2013 at 7:26 am
    Thanks a lot! you (and the answers) saved my life! 🙂
  • John Rofrano
    December 29, 2013 at 2:25 pm
    [Pascual Angulo] “The point is that once I’ve created the multicamera track, the color correction needed for the 3rd cam is lost. Every time I switch to that cam, I need to manually apply the effect: color correction, with a preset made for the specific correction. (I can apply the effect to the whole event, and then select the preset,ok…) There’s a way to select all the takes of the 3rd camera and apply the effect (and the preset well) for it?”
    Just to explain further what is going on. When you use Vegas Pro’s built-in multicamera function, it will do two things to make the multicamera track:
    1. It combines all camera tracks into one master track. That means any FX on an individual camera track will be lost.
    2. It combines all events into a single event with takes on the master track. That means any event FX on the individual camera tracks will be lost.
    Your only option for color correcting individual media is to apply the color correction at the Media FX level.
    Plug-ins like Ultimate S Pro copy the event for a single camera to the master track and therefore event FX are persevered but the built-in multicam support doesn’t let you do this.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Robert Adama
    June 2, 2015 at 3:49 pm
    to John Refrano or those who are concerned
    I am just about to purchase Boris BCColor and Tone to apply for my multicamera work (upto 4 cameras) Question:
    Is this plugin software overcoming this problem( viz. color Fx doesnt work in multicamfunction.
    I tried out the sony Vegas Pro Color FX and None of the functions FX Color can be applied.
    If this correct, than it doesn’t make any sense to buy any plug in, nor the use of the Multi camera functiond does make sense!!
    I hope I am wrong with my Statements.
    Since if it is true, I have to do all my corrections only to the original footage, than to render and than to to Import into the multicam function. Quite a Job!
    I am really looking Forward for an answer
    Robert Adama, Switserland
    Windows7 64bit ASUS P7P55D Intel i7 2.8 GHz, 64BB DDR3-1333
    Graphic Sapphire HD 6870 128 bit
    Vegas Pro 12. Additionally
    Win XP 32bit with AVID Liquid 7.2
  • John Rofrano
    June 4, 2015 at 2:03 pm
    In a multi camera situation, you should do your color correction on the media itself. That is to say, you should add the effects in the Project Media via the Add Media FX menu option when you right-click on a piece of media. This way the media will be color corrected regardless of where you use it on the timeline. All plug-ins work the same way so you cannot buy a plug-in that works different than any other plug-in in this regard.
    ~jr
  • Robert Adama
    June 5, 2015 at 10:39 am
    Thanks for your precise and fast Response! I’ll try it out as soon as possible. The plug in I would like to buy ist BORIX Color and Tone.
    I’ll use the Trial mode and I am looking Forward for the results!
    Thanks again!
    Rob
  • John Rofrano
    June 5, 2015 at 12:36 pm
    You’re welcome. Boris FX plug-ins and some of my favorites.
    ~jr
  • Robert Adama
    June 9, 2015 at 7:01 am
    Wow! it worked fine!!!!!
    now I can order Boris FX Color and Tone
    Tnx again
    (you don’t have to answer again, John (yr last mail you wrote after midnight!!!!¨)
  • John Rofrano
    June 9, 2015 at 11:24 am
    You’re welcome Robert. Glad I could help!
    ~jr
