Activity Forums VEGAS Pro Effects Gone with 32-bit Floating Point
  • Effects Gone with 32-bit Floating Point
    Posted by Mark Prebonich on June 6, 2010 at 1:53 am
    I have some text effects with standard turbulence and gaussian blur. I did some experimenting and set the project from 8-bit to 32-bit pixal format. When I play the clip, the effects seems to have gone away. Why did this happen?
    Another question. When would one want to use the 32-bit pixal format? My video camera is the HDR-CX500V. It has the ability to shoot with x.v color. I currently do not have this turned on. If I shoot video with this setting, I was under the assumption that I would want to set the project to 32-bit floating in order to utilize/keep this additional detail. If I do this then it would seem that I would have difficulty with effects as noted above. Thanks.
    -Mark
    Mike Kujbida replied 16 years, 2 months ago 2 Members · 2 Replies
  • Mark Prebonich
    June 25, 2010 at 2:23 am
    Does anyone have any thoughts regarding this question? Thanks.
    -Mark
  • Mike Kujbida
    June 25, 2010 at 8:06 am
    My guess is that the FX you’re using don’t support 32-bit floating point.
    The online help file has a bit more on this capability.
