Activity Forums Adobe Premiere Pro Effects get stuck during render
  • Effects get stuck during render
    Posted by Bart Slagter on February 6, 2021 at 4:18 pm
    Hey everyone, Im quite new to Premiere Pro. I got the following issue: I’m using a effect on my project, which is Offset, and the Shift Center To with some keyframes to get the picture moving up and down. It all looks well, until I start exporting. Then the effect gets stuck after moving a bit, and then returns to its original position at the end of the effect layer. I’ve tried a lot of things, one of which was lowering the quality of the export. This seemed to help, because with exporting on .avi at low pixels, the problem was gone. Going back to 1080p or even 720p brings back the problem. I’ve tried rendering in almost every format, but nothing seemed to help. Hopefully I’m forgetting something really stupid, but I cannot find out what, does anyone know what it might be? Cheers everyone!
    Todd Perchert replied 5 years, 7 months ago 2 Members · 1 Reply
  • Todd Perchert
    February 9, 2021 at 4:26 pm
    I don’t know what the problem may be. But I’ve got one thing you may try. I’ve had some issues with some effects rendering with GPU acceleration on my home PC, never had an issue with my work Mac like this. But try going to the File menu / Project Settings / General. Change your Renderer to Software Only. Try rendering again. It will take longer to render. But see if that helps with your current render.
    TC
