Activity › Forums › Adobe Premiere Pro › effects change the fieldorder
  • effects change the fieldorder
    Posted by __peter__ on June 3, 2007 at 2:29 pm
    Hello 🙂
    i have a very strange effect in PP2. I selected a (very) large number of clips from several big avi files and placed them in the timeline. Then I wanted to add the timecode effect to give a tape to my client. But suddenly the field order was wrong. Typical shaky, flickery, wrong fieldorder. By testing I found that any effect will cause that problem. So for a workaround I wanted to change the fieldorder manualy again. But that doesnt change it. MAybe it then gets, lets sa, 2 times twisted, as the fieldorder is changes BEFORE the effects are calculated.
    So to be sure I rendered it out with the WRONG fieldorder and the reversed the fields on the resulting clip. Everything is fine then. So it is indeed a wrong fieldorder.
    BUT:
    The stange thing is, when I import the big avis into a new project and add a effect it works again 🙁 So the AVIs are NOT in the wrong order.
    Then I tried to import the whole project into a new one. Same problem.
    The I made the clips offline and connected them again. Same problem.
    So for now I have a little workaround but I need a soultion at least before the final project gets color corrected, which then of course will cause the same problems.
    Had anyone that problem ? What to do ?
    Seems like there is the field order somwhere stored in the clips made from the big clips. But where ? I cannot find anything to change interpretation of fieldorder like in After Effects.
    Thanks for any idea or help!
    _Peter_
    __peter__ replied 19 years, 4 months ago 3 Members · 4 Replies
  • Vince Becquiot
    June 3, 2007 at 10:36 pm
    I’m just curious, did you find this issue was still there after export to a DVD? And what codec is used in the original AVI?
    You can change the field order by right clicking on each clip and choosing Field options > Reverse field dominance.
    Vince
  • __Peter__ Create COW Profile Image
    __peter__
    June 4, 2007 at 6:37 pm
    Hello 🙂
    they are all Matrox DV-Cam codec.
    It would have been there if a did a DVD with the wrong fielorder. I could have reversed it at encoding, but thats not really a solution.
    As I wrote the reverse fields did’t change anything.
    Any ideas anyone ?
    _Peter_
  • Harm Millaard
    June 4, 2007 at 6:43 pm
    Matrox reverses, for some obscure reason, field order. Normally you have LFF, but when using Matrox it suddenly is UFF. Wierd, but that is how it works.
    __peter__
    June 4, 2007 at 8:52 pm
    But that never happened before in the same workflow.
    And as I wrote: If I try to reproduce the problem from the same clips – there is no problem. Only those.
    So somehow the single clips which are only “virtual” clips from a big AVI hav reversed fields. NOT the source AVI.
    Anyone else ? 🙂
    _Peter_
