Activity › Forums › Panasonic Cameras › Effects and color corection better in uncompressed HD
  • Effects and color corection better in uncompressed HD
    Posted by Jean-yves Le moine on October 3, 2005 at 10:36 am
    did someone make test with footage DVCproHD 1080
    footage in dvcproHD by FW and same footage in uncompressed HD via SDI (use the 1200 A)
    apply the same effeccts and somme heavy color correction
    Is there a difference is it the same in FCP and other tools ala shake and AE?
    because people say that uncompressed is bettter for effects but i thought it was the same as FCP transform dvcpro HD to uncompressed make the effects and back to dvcpro HD
    thanks
    jean-yves le moine
    temps r
    Randall3 replied 20 years, 12 months ago 4 Members · 4 Replies
  • Toke
    October 3, 2005 at 2:52 pm
    Depends on your master format. If you go bak to dvcprohd then it’s of course the same.
    If your master format is something else, then editing with dvcprohd codec is just one more generation of compression in workflow that decreases the quality a little.
  • Randall3
    October 3, 2005 at 2:56 pm
    The advantage to uncompressed footage for color work is when it is recorded to 10bit. The 1200a is an 8bit deck and pulls in SDI footage as DVCPRO-HD (8bit) You would need a D5 deck to pull in footage as D5 10bit. Or go through one of the HD-SDI cards for the FC or into an AVID machine to thier DNxHD 10bit.
  • Donatello
    October 3, 2005 at 4:39 pm
    shoot DVCPRO50 , DVCPRO 720p, dvcpro100 with CONFIDENCE – render (using DVCpro50/720p/1080 codec) with caution .. DVCpro 720P & 1080 uses alot of compression
    https://codecs.onerivermedia.com/ click on 4:2:2 C -for test of apples dvcpro codec’s
  • Randall3
    October 4, 2005 at 2:23 am
    It brings up the BIG problem for HD editors, namely, if you are not monitoring (at least part of time on a large HD display) you will not see the problems until after delivery. It is about detail after all – and man-o-man, are the problems ever going to show! When you’re color correction starts looking like a special effect – you know you’re in trouble.
