Activity Forums VEGAS Pro Effects Affect Entire Timeline
  • Effects Affect Entire Timeline
    Posted by Eric Martin on March 23, 2009 at 6:50 am
    Hey there,
    New to Vegas and having an effects issue. When I add effects to a clip, it not only affects the clip in question, but every clip in the track/timeline. Am I adding it downstream, is this preference issue,
    is this a “chaining” anomaly, do I have to seperate tracks, what? Can’t seem to see what I’m doing
    wrong…
    Edward Troxel replied 17 years, 5 months ago 3 Members · 2 Replies
  • Dave Gaham
    April 11, 2009 at 8:46 am
    I am having the same problem where I have a video track to only use for Picture-in-Picture and each time I place a new Picture-in-Picture in the video track in a different spot all the others move to the same area which I definitely don’t want
    I tried Track Properties ungroup but it made no difference
    I asked in this forum but haven’t got a solution to my problem
    Where are all the experts !!!
    in Premiere it is very easy to move PiP’s to different spots and I am sure once I can find the answer it will be as easy in Vegas
    I am certain we have both clicked on the same thing that then applies to the whole track even though our problems are different the answer for both should be the same
    If I find out I will let you know and if you find out can you mention here what the solution is ?
    …… excuse me ……. back to reading the manual !!!
    Regards from Dave
  • Edward Troxel
    April 11, 2009 at 1:59 pm
    [Dave Gaham] “I am having the same problem where I have a video track to only use for Picture-in-Picture and each time I place a new Picture-in-Picture in the video track in a different spot all the others move to the same area which I definitely don’t want”
    You MUST create new keyframes instead of adjusting the first keyframe. On the timeline at the bottom of the Track Motion window, add new keyframes on that timeline.
    Edward Troxel
    JETDV Scripts
