Activity › Forums › Apple Final Cut Pro Legacy › Effects
Effects
Posted by Eric Perlman on July 10, 2007 at 5:32 pmi want to add the same effects to multiple clips. how can i do this without copying and pasting all the motions settings and filter settings in the clip?
Eric
Russell Lasson replied 19 years, 2 months ago 2 Members · 3 Replies -
Russell Lasson
July 10, 2007 at 6:27 pmI usually select the clip and hit edit – copy. Then select the rest of the clips and select edit – paste attributes. Then select which setting you want to paste.
But it sound like you only want one filter to be applied. Another way to do this is to open the clip in the viewer and open the filters tab. Now select all of the clips you want to apply the filter to. Drag the filter from the filter tab down onto the selected clips in the timeline. It should apply the filter to all of those clips.
-Russ
Eric Perlman
July 10, 2007 at 8:35 pmis there a way to save these attributes in a bin so i don’t have to fish around the timeline?
Russell Lasson
July 10, 2007 at 11:53 pmYou can make it a favorite filter that you can apply.
For basic motion settings you could apply the settings to any clip in the browser and then copy and paste the attributes from that clip to a clip in your timeline.
-Russ
