Activity › Forums › Adobe After Effects › Effecting Scale values of an object or multiple objects with a ramp.
  • Effecting Scale values of an object or multiple objects with a ramp.
    Posted by Jordan Montreuil on February 9, 2012 at 6:43 pm
    I am looking for a way to incorporate the ideas of Cinema 4D’s Effectors. I would like to be able to use a ramp layer to drive values of other objects, be it Position, Scale, Rotation, etc. Maybe I can plug the 0-255 white values of a ramp into the values of the other objects?
    For Example:
    Have a group of objects with that scale up from 35-85% as a hidden ramp animates in space underneath them.
    Is there a way to do this?
    Roland R. kahlenberg replied 14 years, 7 months ago 3 Members · 2 Replies
  • Walter Soyka
    February 9, 2012 at 7:20 pm
    Yes, you could, via expressions. You’d use sampleImage() to read the ramp, and interpolation functions like linear() and ease() to map its output values to your animation input values.
    I think there are better (and faster-to-render) ways, though. You could build your own rigs using the controls found in Expression Controls. You can link parameters directly very easily with the pickwhip [link], or again, you can use more involved expressions.
    Here are a couple good resources to get you going with expressions:
    https://www.motionscript.com/
    https://www.jjgifford.com/expressions/basics/index.html
    Walter Soyka
  • Roland R. kahlenberg
    February 9, 2012 at 7:26 pm
    The sampleImage Expression will do this quite nicely. There are a few examples at the COW’s AE Expressions Forum. Search for sampleImage and go through the results.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
