Activity › Forums › Apple Final Cut Pro Legacy › Effected Still Preview looks different from rendered version FCP 7.0.3
  • Effected Still Preview looks different from rendered version FCP 7.0.3
    Posted by Peter Simon on February 1, 2013 at 5:10 pm
    I’m at a new job… with a new computer with FCP 7.0.3. I’m trying to color correct some footage in the timeline using 3-way CC. eyeball the footage and use the sliders to take the blacks down until right before losing detail and the whites up… using the Canvas preview. Then when I render, it renders out darker than what I was just seeing. I can’t figure out what is happening. This never happened on any other FCP I’ve used. I have a computer at home and used FCP at my old job. Neither have done this. Any suggestions?
    Peter Simon replied 13 years, 8 months ago 2 Members · 4 Replies
  • Shane Ross
    February 1, 2013 at 5:44 pm
    What is the codec of this said footage?
    Shane
    Little Frog Post
  • Peter Simon
    February 1, 2013 at 6:01 pm
    Sorry… I’m working with H.264 from a Canon T2i. This was the first time in a while that I edited footage straight from the camera. Usually I convert it to ProRes first, but I didn’t think I had time for that with this project.
  • Shane Ross
    February 1, 2013 at 6:05 pm
    I KNEW IT!!!
    And now you see why you need to convert to ProRes before you edit. FCP and H.264 don’t mix. And you even knew better, but did this anyway! 🙂
    Want to edit native without converting? Get PRemiere Pro.
    Shane
    Little Frog Post
  • Peter Simon
    February 1, 2013 at 6:09 pm
    I had an inkling that might be the problem, but wasn’t sure. Thanks for the confirmation.
