Activity Forums Adobe After Effects Expressions Add Effect to layers with expressions erros in all comps
  • Add Effect to layers with expressions erros in all comps
    Posted by Otávio Nascimento on November 11, 2022 at 3:38 pm
    How to add an effect to all layers with expression errors in all comps?
    I have this expression:
    var effectMatchName = "ADBE Fill";
    var comp = app.project.activeItem;
    for(var i = 1; i <= comp.numLayers; i++){
    comp.layer(i).Effects.addProperty(effectMatchName);
    Dan Ebberts
    replied 3 years, 10 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    November 11, 2022 at 8:02 pm
    You’ll need a recursive property sniffer to check for expression errors. Something like this should be close:
    var foundOne;
    function processProperty(theProp){
    if (theProp.propertyType == PropertyType.PROPERTY){
    if (theProp.canSetExpression && theProp.expressionError != ""){
    foundOne = true;
    }else{ // must be a group
    for (var i = 1; i <= theProp.numProperties; i++){
    if (! foundOne) processProperty(theProp.property(i));
    var myComp, myLayer;
    for (var i = 1; i <= app.project.numItems; i++){
    if (app.project.item(i) instanceof CompItem){
    myComp = app.project.item(i);
    for (var j = 1; j <= myComp.numLayers; j++){
    myLayer = myComp.layer(j);
    if (! myLayer.locked){
    foundOne = false;
    processProperty(myLayer);
    if (foundOne){
    myLayer.property("Effects").addProperty("ADBE Fill");
  • Otávio Nascimento
    November 11, 2022 at 9:58 pm
    Thank you Dan. It helps a lot. But maybe I need other solution for my problem:
    I made a plugin and used it a lot in my project. Now I want to add a ‘checkbox’ in my plugin. If I add it I will receive a warning in my project and will glitchy my project. There is a good solution for it?
    My idea was to remove the plugin from all the project and add after I edited the plugin but I noticed that I will lose the keyframes and expressions.
  • Dan Ebberts
    November 12, 2022 at 12:26 am
    It’s been a while since I’ve done much with plugin code, but I seem to recall that when you add a new control to your plugin, you just need to make and assign it a new, unique id and it should be backwards compatible. It sounds like you may have had a different experience.
