Activity › Forums › Apple Final Cut Pro Legacy › Effect to layer question
  • Effect to layer question
    Posted by Don Wilson on May 10, 2005 at 12:38 am
    I thought you used to be able to do this in FCP and forgive me as I run an Avid most times, but can you add an effect to a layer above edits to effect all clips below in FCP HD?
    Don Wilson
    AmericanaMediaInc.com
    Walter Biscardi replied 21 years, 4 months ago 3 Members · 2 Replies
  • Kevin Monahan
    May 10, 2005 at 1:14 am
    Nest the clip. Add the effect to the nest.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Walter Biscardi
    May 10, 2005 at 11:20 am
    Another way to do this to maintain some individual control over the clips is to apply the filter to the first clip, then “Copy”, then select the rest of the clips and “Paste Attributes – Filters.” This will apply the filter to every single clip selected and you can go into any of the clips individually and make adjustments to the filter.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
