Activity › Forums › VEGAS Pro › Effect to enhance color?
  • Effect to enhance color?
    Posted by Jaanus Henno on June 23, 2012 at 11:31 am
    Hi!
    I have a video filmed inside with indoor lighting, so all colors look yellowish. The camera was cheap, so even when I use color correction effect, I can take the yellow down but then color looks like bleached, no richness. Is there any way to compensate it, make it realistic?
    Some 3rd party filter?
    Jaanus Henno replied 14 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    June 23, 2012 at 11:40 am
    Please post a screenshot of the footage before you applied any FX to it so that we can have a look at it and make recommendations.
  • Jaanus Henno
    June 23, 2012 at 11:59 am
    Ok, here it is!
    The quality is really bad, what to do.
  • Mike Kujbida
    June 23, 2012 at 12:21 pm
    Is this any better?
  • Jaanus Henno
    June 23, 2012 at 1:14 pm
    Hey, that’s pretty good! Thanks for the help! That’s much better than I could do, thanks for the tip.
    I think I saw somewhere an effect from the Boris Continuum package which made colors nice rich, although it can be pretty much also achieved with the levels.
  • Mike Kujbida
    June 23, 2012 at 2:01 pm
    Glad I could help you.
    Vegas has some very powerful color correction tools but it does take time to master them (and I’m not even close to being there!!).
    It also helps a lot to start with a clean image.
  • John Rofrano
    June 23, 2012 at 2:33 pm
    If you want to boost the colors, just increase the Saturation on the Color Corrector in Mike’s screen shot (I see it’s still set to 1.0)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Nigel O’neill
    June 27, 2012 at 3:26 am
    You might also want to adjust the color curves to boost the overall intensity, and by selecting colour channel (R, G or B), selectively boost or reduce that color.
    You will need to fine tune by eye using the mid and high color wheels of the color corrector fx to remove the color cast, or apply the secondary color corrector fx and tweak that.
    I have seen and corrected much worse 🙂
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Jaanus Henno
    June 27, 2012 at 9:55 am
    Thank you very much for the help. That really does a great job!
