Activity Forums Apple Final Cut Pro Legacy Effect Stops Mid Clip.
  • Effect Stops Mid Clip.
    Posted by Ian Cooley on November 27, 2007 at 5:42 am
    I am color correcting using in FCP6 using the basic 3way color corrector filter. Mid way through the clip, the color adjustment just seems to quit as if no filter had been applied. The only solution, so far proving to be inadequate, is to cut the clip at the point where the effect stops and add another color corrector filter to readjust. Wonder what is going on here and how I can fix it.
    Ian Cooley replied 18 years, 10 months ago 2 Members · 2 Replies
  • Rafael Amador
    November 27, 2007 at 11:31 am
    Haven’t you move the filter limiters? You know, the small vertical bars situated in the top line of the Filters tab.
    Normally they are in the IN and OUT point of the clip, but if you move them the Effect will start or will finish where you set the bars.
    Rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
  • Ian Cooley
    November 27, 2007 at 4:01 pm
    I should have posted this in the FCP basics forum…apologies.
    ian
