Activity Forums Adobe After Effects effect papers flying (ae)
  • effect papers flying (ae)
    Posted by Dayats on May 22, 2006 at 10:46 am
    Hello, to see if somebody a little can orient me since to do with Ae as papers (in this case photos) that they are falling of the sky
    Ryan Hill replied 20 years, 3 months ago 2 Members · 1 Reply
  • Ryan Hill
    May 24, 2006 at 3:06 pm
    You could try applying this to each paper layer:
    https://www.aenhancers.com/viewtopic.php?t=8
    There’s also shatter. Put all the papers on one large layer and apply a custom shatter map so each paper is its own shattered piece. There’s an example somewhere on Creative Cow where someone used that to make falling leaves.
    Some of the particle plugins might also be up to the task, but I can’t think which has got 3D tumble for particles.
    All these solutions treat the papers as rigid. If you want the papers to bend and curve as they fall, you will need 3D software.
