Activity › Forums › Adobe Premiere Pro › Effect not working
  • Effect not working
    Posted by Ronaldo German on September 19, 2011 at 12:18 pm
    I can not figure out how I can apply a fade out (opacity) in the end of a clip I slowed down (slow motion). The effect do not work, despite I can see the keyframes (opacity) correctly in the timeline.
    Premiere Pro 5.5
    Ronaldo German replied 15 years ago 3 Members · 6 Replies
  • Jeff Pulera
    September 19, 2011 at 2:28 pm
    Hi Ronaldo,
    I don’t know why the Opacity settings would fail, but you can always just drop a Dissolve transition onto the end of the clip
    Jeff Pulera
    Safe Harbor
  • Ronaldo German
    September 19, 2011 at 5:21 pm
    Thank you
    In fact I decreased the speed to 1% – freeze frame.
    In this case, dissolve also didn`t work, but I found out if I nest the clip it works.
  • Jeff Pulera
    September 19, 2011 at 5:37 pm
    If a freeze frame is what you want, may I suggest you simply create one rather than messing with speed changes that bring about other issues.
    Just click the “camera” icon below the Program Monitor window to create a still image of the currently displayed frame. That still image can then be imported and used in the timeline sequence. It can be dragged to any length, and effects and transitions applied without issues or workarounds needed.
    Jeff Pulera
    Safe Harbor Computers
  • Ronaldo German
    September 19, 2011 at 6:03 pm
    Thank you Jeff.
    But I was trying to fade out a freeze frame from the end of a slowed down moving clip.
    Best regards
  • Ann Bens
    September 19, 2011 at 7:56 pm
    Cut of the last frame of the slowing down clip.
    Make a Hold Frame and stretch it with the stretch tool.
    Add a dissolve or keyframe the opacity.
    Adobe Certified Expert Premiere Pro
  • Ronaldo German
    September 19, 2011 at 8:32 pm
    Thank you Ann
    I`m new to Premiere (coming from buggy Vegas Pro last versions).
    So I will look for this stretch tool.
