Activity › Forums › Blackmagic Design › Effect Handling with Decklink HD Pro PCI-e?
  • Effect Handling with Decklink HD Pro PCI-e?
    Posted by Eric Jones on February 19, 2007 at 4:05 am
    Under my system settings/effect handling tab there is not a choice for Decklink to handle the effect processing. Does this version of the card not handle effects? My only choices are Final Cut Pro and None.
    Also, I’m running a SD edit captured with the Blackmagic 8-bit YUV codec. My Sequence is set up with the exact codec parameters, frame rate, etc. When I apply an sort of effect I need to render (red bar). Also, there are no options to change in the RT effect switch located on the timeline window.
    And lastly, in a 10-bit RGB sequence, are the effects rendered in 16-bit RGB or only 8-bit? I notice the extended range option for YUV projects but only a Render in RGB for RGB projects with no specification for bit-depth.
    Any thoughts?
    Eric Jones
    Kaspar Kallas replied 19 years, 7 months ago 2 Members · 1 Reply
  • Kaspar Kallas
    February 19, 2007 at 5:35 am
    FCP does not render higher than 8 bit RGB
    -Kaspar
