Activity › Forums › Media 100 › Effect failed to render
  • Effect failed to render
    Posted by Doug Calhoun on March 16, 2016 at 6:42 pm
    Hi all, I’m running M100 Suite 1.5.1 on OS 10.6.2 and just started getting an effects rendering error. A simple push of 1 sec creates an “Effect Failed to Render because source material can’t be found.” Video plays fine and otherwise the system is working normally.
    Any suggestions or thoughts on why this is happening. I’ve had so few problems with M100 that I can’t even remember which pref files to toss to help rectify this and couldn’t find a similar problem in a search.
    Thanks in advance.
    Doug Calhoun replied 10 years, 6 months ago 1 Member · 1 Reply
  • Doug Calhoun
    March 16, 2016 at 7:16 pm
    problem solved. Render media destination somehow was flagged to a “Recovery Drive”. Not sure how that happens but all is fine now.
