Activity Forums Adobe After Effects Effect error at startup
  • Effect error at startup
    Posted by Bronson Hoover on April 21, 2012 at 1:30 am
    I’m stuck in an endless loop. Everytime AE opens, I get an error message saying that AE is having a hard time initializing the effect Knoll Light Factory, and then it crashes.
    Is there a way to disable effects at startup? Do I need to trash the effect that’s in the effect folder and re-load the effect?
    Any suggestions?
    Thanks.
    ++bronson
    Bronson Hoover replied 14 years, 5 months ago 2 Members · 2 Replies
  • Brian Charles
    April 21, 2012 at 1:58 pm
    Before trashing the effect, try reverting After Effects Preferences to their defaults by holding down the Control + Alt + Shift keys while launching the application. (Command + SHift + Option on the Mac).
  • Bronson Hoover
    April 22, 2012 at 9:35 pm
    Thanks for your advice Brian. I decided to try something else before I took your advice. I hate having to reset all of my preferences, and I always try to make that my last ditch effort.
    I moved my Knoll Light Factory folder (HD/Library/Application Support/Adobe/Common/Plug-ins/CS5.5) to my desktop. Then I restarted AE and deleted the layer that had the Knoll Light Factory effect that was causing the trouble. Then I saved the project, restarted AE, and had no problems. Then I closed AE, returned the LF folder to the original folder and restarted AE.
    And I’m good as gold. I figured I share my solution in case anyone else has the same problem.
    Thanks.
    ++bronson
