effect controls – slider parameters – 7 values, slider jumps directly from 0 to 1
hi
is there a way to edit the effect controls slider parameters, so that I have just 7 values? (I’m using the slider control to animate mouth shapes from a character, which are time remapped, and the time remapping is linked to the slider control) When I edit the slider parameters, I can adjust that the range is from 0-7, but if I use the slider it’s going through 0.01, 0.02, 0.03… etc. It would be nice when the slider would jump directly from 0 to 1 to 2 to 3 etc.
jadwiga
