Activity Forums DVD Authoring eDVD4 error message
  • eDVD4 error message
    Posted by Bob Cole on December 8, 2006 at 5:41 pm
    I’m using eDVD4 successfully on the first, now-underpowered computer on which I installed it.
    I tried to shift eDVD to another computer recently. I went through the whole rigamarol of getting a license key from Sonic, and the program seemed to install correctly. But I encounter the following error every time I try to use it, after inputting the basic project set-up info (folder location, size, skin, etc.):
    “Error parsing automatically-generated video XML description file.”
    What does this mean, and how can I fix it? The first computer, on which eDVD works fine, is an HP xw4100; the second computer, which generates the error message, is an HP xw8200; both are running XP Pro.
    — Bob C.
    Adam Bolt replied 18 years, 5 months ago 3 Members · 5 Replies
  • Ss Scott
    December 8, 2006 at 7:56 pm
    It means that interactual player is not working on your computer and thus eDVD can’t use it to parse your video_ts. if you get IA working you will get eDVD working. here’s a possibility. run your DVD player on your new computer. you may need to play a DVD once for the mpeg decoders to get registered. If IA can’t see your MPEG decoders, it is not going to work properly.
  • Bob Cole
    December 9, 2006 at 2:30 pm
    Wow — you nailed it.
    I had never installed a DVD player on that computer. Once I did, all was well.
    Thanks very much.
    — Bob C
  • Adam Bolt
    April 2, 2008 at 1:53 pm
    I have exactly the same error message.
    The previous solution was to run InterActual player first and then create the eDVD project, but InterActual Player does not open and I have no option to play a DVD using InterActual.
    I too am running a trial version of eDVD and have created a VIDEO_TS file with Encore.
    Any other solutions known?
  • Bob Cole
    April 2, 2008 at 3:54 pm
    I haven’t used eDVD for a long time, so I’m rusty, and I hope someone smarter sees your question.
    But in case no one else replies: my problem turned out to be totally simple — no DVD player had been installed on the computer.
    IA still needs some “base” DVD player, I guess. So try installing a DVD player.
    Hope this helps — I bet it doesn’t.
    Bob
    MacPro 2 x 3GHz dualcore; 10 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
  • Adam Bolt
    April 2, 2008 at 4:36 pm
    Thanks very much for the reply.
    Yeah, I wouldn’t be using eDVD at all if Encore had an inbuilt hyperlink facility.
    I already have a DVD player installed – I use AVS DVD Player. So not sure why it’s giving me a problem. Did you have the problem that you couldn’t open InterActive as well as that error message (before you fixed it) ?
    I might try installing another DVD player or a codec pack.
