Activity Forums DVD Authoring eDVD question
  • eDVD question
    Posted by Bpetefla on October 15, 2006 at 1:32 am
    I’ve got a project all ready to record to DLT, but I’ve decided to go back to some of the mixed .wav files and boost them a bit. Which means I’ll have to replace the old ones in Encore, transcode, and build the project again.
    If I make no other changes to the project, and I name the build folder the same, can I use the existing eDVD files? Or do I have to build the eDVD files all over again?
    bpete
    Wts(jmanz) replied 19 years, 10 months ago 2 Members · 1 Reply
  • Wts(jmanz)
    October 15, 2006 at 4:01 am
    Pete,
    As long as you don’t change the structure of your dvd–ie you don’t change your menus or title sets/chapter marks/and the like, then you should be OK. Try swapping the Video_TS folder you originally created your eDVD project off of with the newly created Video_TS folder (with your wave file substitutions). Just remove or place the original Video_TS folder elsewhere, and place your new one in it’s place. If you reopen the original eDVD project it will run off of the newly replaced Video_TS folder (because it doesn’t know you swapped it out). Build and simulate the project and see if it works like it did before (it should, but it’s a quick way to test it out before sending your disc off for a big run).
    Jim
