Activity Forums DaVinci Resolve EDL with reversed clips into DaVinci ?
  • EDL with reversed clips into DaVinci ?
    Posted by Manuel Wenger on March 14, 2011 at 6:35 pm
    I´m working on an Imagefilm shot on Red and cut in FCP using the M Proxies.
    When i import the EDL to Davinci everything confirms fine to the R3D´s.
    There is just one clip which will show up as red cross in the timeline.
    I figured out it was played backwards in the FCP cut.
    I´m trying to fix this shot within DaVinci using the Timeline Editing functions, but i´m not sure if i can reverse the shot in there.
    If i try it with Adjust speed, I can´t put a minus in front.
    Does anyone know how i can fix that ?
    thanks
    Manuel
    Manuel Wenger
    DOP / DIT / Digital Colorist
    Munich – Germany
    Charlie Edison replied 15 years, 5 months ago 2 Members · 1 Reply
  • Charlie Edison
    March 15, 2011 at 6:13 pm
    Try splitting and adding just that shot with handles twice as long as the edit and then on your time line select reconform from reels
    My guess is resolve is not adding enough length to the shot for it to play it backwards
    To confirm, write down the timecodes for that shot and then check the media pool for the shot, sort the media pool by source timecode to assist finding the shot
