Activity Forums Blackmagic Design EDL Success
  • EDL Success
    Posted by Adrian Tecson on May 26, 2006 at 7:31 am
    Anyone have success exporting a proper EDL when doing a BMD DV offline? I’ve been trying to do that but I always end up doing the EDL manually cause the proper timecodes aren’t exported. I also have the same experience when batch digitizing from an imported EDL. I and up making offline files manually with the marked timecodes and batch capturing from that.
    Adrian Tecson replied 20 years, 2 months ago 1 Member · 1 Reply
  • Adrian Tecson
    June 8, 2006 at 10:52 am
    Just a follow up on this topic. I found out that EDL import works fine as long as there are no speed ups on the clips. If there are, then the batch captures files are shorter than whats needed. Anyone else have this experience?
