Activity Forums Apple Final Cut Pro Legacy EDL question
  • Posted by David Jakubovic on November 30, 2006 at 9:30 pm
    Hello,
    In the FCP’s EDL generator, does anyone know what the “REEL CONFLICTS” options – of which there are three: “B reel edits”, “preread edits” and “generic edits” – does anyone know what these mean? I can’t seem to figure it out except that with the “B Reel edits” option clicked, it makes a second, very short EDL, marking things that make no sense to me at all…
    Thank you
    David
    “We’ll fix it in post”
    David Jakubovic replied 19 years, 9 months ago 3 Members · 3 Replies
  • Joe Paolo
    November 30, 2006 at 9:41 pm
    Back in the bad old days you could not transition from the same tape reel. You had to broll any concurrent shots from the same reel. Use the preread or geneic setting unless you’re onlining with 1980s equipment.
    joe
  • Tom Matthies
    November 30, 2006 at 9:42 pm
    The “B-Reel” option is a carry over from the linear tape to tape edit days. It teels you that two shots that are to joined by a transition are both on the same reel of tape. Obviously, when editing from tape, it can’t playback from two different spots on the tape at the same time. The solution was to dub one of the shots(or the entire source tape) over to a “B” reel that would play back on another machine which enabled you to transition from one shot to the other shot. A little later on, machines were developed that would do “Pre-read” edits where the outgoing shot would playback from the master record machine, thru your switcher where you would mix the incoming scene from a source tape and then record it back on the master deck. Basically the record machine was capable of playback and record at the same time. The master record machine had two sets of heads that were avtive at the same time basically making it do the duties of both a source machine and a recoed machine.It was a huge time saver. The only problem was that the process was destructive. You only got one chance to “Hit the reds” and get it right the first time. If you messed it up, you would have to go back and rebuild the previous scene on the master tape. It sounds a bit complicated but it worked very well in practice once you got used to the process.
    If you are trying to generate an EDL to take into a tape to tape online room, you will need either the B-reel list or the Pre-read list for the editor. If it’s going into another non linear system, don’t worry about it. Just turn that feature off and you will be good to go when you generate the EDL.
    Tom
  • David Jakubovic
    November 30, 2006 at 9:58 pm
    Ah!
    Thank you very much, gentlemen. That makes perfect sense…
    David
