Activity › Forums › Adobe Premiere Pro › EDL problem
  • EDL problem
    Posted by Fredrik Brofalk on September 2, 2010 at 2:17 pm
    Hi!
    I have a old edl (both in Sony and CMX formats) thay i wan´t to capture. But there is one problem with the edl. The audio tracks are missing so when i´m capturing i oly get the video, no audio. How can i get the audio. Is there a way to edit the edl and add audio or get Premiere to include the audio as well?
    No fancy editing in the edl, just straight cuts and some inserts.
    regards
    Fredrik B
    Fredrik Brofalk
    Mediacenter
    University of Kristianstad
    Alex Udell replied 16 years ago 2 Members · 1 Reply
  • Alex Udell
    September 2, 2010 at 2:33 pm
    Would it be possible from Premeire to generate a sample edl that includes an audio edit so you could see how it was set up…
    Then using a text editor, modify your original edl to match that spec?
    hopefully you can find a text editor with some macro capabilities so you could automate it a bit.
    Alex
