  • Posted by Hernan Torres on August 23, 2006 at 7:35 pm
    Hello Everybody
    I know is weird, but someone know where I can find an EDL management software as the old Edit Lister or Edit Master?
    My intention is to build an edl manually using the TC window burned in the reference video provided by the client. That guy digitized the media in FCP manually (without machine control).
    Is all I have
    Hernan Torres
    Mark Raudonis replied 20 years ago 3 Members · 2 Replies
  • Alessandro Capitani
    August 24, 2006 at 6:53 am
    [HTedit] “My intention is to build an edl manually using the TC window burned in the reference video provided by the client. That guy digitized the media in FCP manually (without machine control).”
    there is a more efficient way to do this in FCP.
    1) digitize the material for your editing session without machine control
    2) select one clip at a time in the browser and go to Modify->Modify Timecode. Enter manually the timecode using the timecode burnt on the video as reference. You can use either the timecode at current position or the reference for first frame of the clip.
    Hope it helps.
    Ale.
  • Mark Raudonis
    August 24, 2006 at 9:04 am
    Ale’s suggestion is a good one.
    But if you still want to go “old school”, here’s where you can find “Edit Lister”.
    https://www.mcqpro.com/html/EListerTracker.html
    mark
