Activity › Forums › Avid Media Composer › EDL Manager TC error
  • EDL Manager TC error
    Posted by Rik Flynn on February 3, 2010 at 4:14 pm
    Hi
    I am looking for some advice regarding EDLs. Every time I output an EDL through EDL Manager the source timecode is listed for each clip as if the TC starts at 00:00:00:00. So for example in a clip where my In point is say 6:33:11:06, in the EDL the clip in point is listed as 00:00:59:01 because my IN point happens to be 59 seconds and 1 frame into the clip.
    I am dubious if this is the correct EDL format. If I import the EDL into FCP it will try and find timecode 00:00:59:01 but won’t find it in that clip and so just chooses IN point as being the earliest possible frame in the clip.
    I read somewhere that you need to give each clip a Tape name for this to work out, but this is one of the only fields which is unmodifiable in Avids bins. But I have given the clips a labroll number and chosen that as ReelID in EDL Manager but that didn’t help.
    Please help as this is part of an earlier problem I am having trying to get XDCAM EX footage into Color without a gamma or colour space change.
    Thank you very much for your time.
    Michael Phillips replied 16 years, 7 months ago 2 Members · 1 Reply
  • Michael Phillips
    February 7, 2010 at 6:22 pm
    Imported files do not have the TAPE MOB needed to generate an EDL in the first place, regardless of which field you use as source. This is something that is being looked into.
    Michael
    Michael Phillips
