Activity › Forums › Avid Media Composer › EDL Manager hangs with some S3D clips
  • EDL Manager hangs with some S3D clips
    Posted by David Steiner on June 5, 2012 at 6:21 pm
    I’m having serious issues getting out of Avid with S3D projects.
    The problem is very simple: for some clips, EDL manager hangs – systematically, not once in a while. I tried everything, it just hangs. But not always – only for certain S3D master clips which have nothing different from the others.
    I prepared bins with the master clips, both 2D sources and S3D clips (XDCAM and DNXHD185, both native Avid MXF – no AMA at all), and the “EDLBugForAvid” bin, with self-explanatory names.
    For “generique”, cutting only ONE frame at the end of the sequence makes it work.
    Here is the bins, if anyone would like to try:
    https://convergence3d.net/EDLManager_Hangs_Bins_and_Dumps.zip
    “_hangs” means the sequence makes EDL Manager hang, and “_works” means EDL Manager can output the EDL.
    The EDL Manager bug is:
    “Bus Error” in thread “MainThread”, at address 0x0
    Anyone had this problem too?
    David Steiner
    Parallell Cinéma
    https://www.parallellcinema.fr
    system: Mac OS X 10.6.8 Avid 6.0.1
    Bugs in events.log:
    20120605193214 Ready Application ready for user
    20120605193214 FatalAbort Assertion failed: start_source == end_source, file /Snapshots/relengsnow5_1327452620/ppg/MCTop/ProjectFiles/../../EDL_Mgr/EDL_Core/edlDecompose.c, line 3131
    20120605193214 Dump Dump report written to Dump_2012.06.05_19.32.14.txt
    20120605193214 FatalErr A serious program error has occurred.|Restarting the application is recommended.|If you need further assistance record the following|information and call Avid Customer Support:||Error: Assertion failed: start_source == end_source|File: /Snapshots/relengsnow5_1327452620/ppg/MCTop/ProjectFiles/../../EDL_Mgr/EDL_Core/edlDecompose.c, Line: 3131
    20120605193215 Shutdown Application is terminating normally
    20120605193215 Shutdown Shutdown in __FtlAbortm
    David Steiner replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
