EDL HELP!!!! Emergency
Ok. I have a 19 layer timeline, prepping an EDL for the effects house. One EDL per video layer.
I loaded DVCAM downconverions of 1080/23.98 – loaded them without 3:2 so I have matching timecode to the D5. Working in a 23.98 DV timeline.
My CMX3600 EDL is completely wrong on Source Timecode. The IN points are drifting anywhre between 8 frames and 10 seconds. For instance, my second event reads on the EDL as 01:16:30:23 – when in FCP the clip starts at 01:01:30:14. FCP has all the correct timecodes, I can match frame anywhere in the edit, and I have the correct TC to match burn in. The EDL has a note reflecting the 24p timecode….
Anyone have any ideas? This is the first time I’ve tried to do a 24p EDL, vs a 30 and converting it with Cinema Tools.
HELP!!!! THANK YOU!!!!
