Activity Forums Avid Media Composer EDl from FCP to AVID?
  • EDl from FCP to AVID?
    Posted by Derik Thadd on June 21, 2007 at 8:26 pm
    What is the best way to get an EDL from Final Cut pro to Avid?
    I am trying but can’t get any audio to show up in the Sequence once I get it into Avid.
    Also, some of the edits in my timeline are not in the sequence once I get it into Avid.
    Geraint Pari huws replied 19 years, 2 months ago 3 Members · 2 Replies
  • Joe Womble
    June 21, 2007 at 8:33 pm
    The very best way?
    https://www.automaticduck.com/products/pefcp/
    Regards,
    Joe Womble
  • Geraint Pari huws
    June 22, 2007 at 9:20 am
    Or,strip your sequence as far as you can, edls, whatever their type struggle with almost anything more complicated than a wipe, dissolves to and from material on the same spool may require you to specify a b reel etc when creating an edl.
    You may need to build a simplified sequence prior to pulling an edl,and be very carefull that you’re edl export settings and import settings are as close as they can be considering the differant packages.
    Edit B offer a few cool little free packages that might hel you.
    You mmay find that a medialess omf might be of more use.
