Activity Forums Apple Final Cut Pro Legacy EDL event limit?
  • EDL event limit?
    Posted by Aaron Neitz on February 23, 2006 at 1:57 am
    We’ve got a 90 minute piece, stripped down to cuts and dissolves, 1 layer… FCP 5.0.4 just won’t output an EDL. It goes through the motions, but there’s no file saving anywhere. I’m completely at a loss….
    Aaron Neitz replied 20 years, 7 months ago 5 Members · 5 Replies
  • Debe
    February 23, 2006 at 2:22 am
    Grass Valley does have an event number limit. For the life of me, after over six years, I can’t remember what it is. I wouldn’t be surprised if CMX does, too.
    Which format are you using?
    Try breaking it in half, or better yet, in thirds, and see if that works. You should be able to keep timecode intact by not ripple deleting.
    debe
  • Michael Gissing
    February 23, 2006 at 8:04 am
    CMX3600 EDL’s have a limit of 999 events. A 90 minute program will likely exceed that limit. Splits are the way to go
  • Doug Bassett
    February 23, 2006 at 1:33 pm
    Not sure what you’re finishing on but what about XML?
  • Karim Zouak
    February 23, 2006 at 1:36 pm
    I had that problem briefly, too, but it went away after I trashed preferences….
    good luck,
    -karim
  • Aaron Neitz
    February 23, 2006 at 5:26 pm
    thanks! will try a plan B
