Activity Forums Apple Final Cut Pro Legacy EDL Conversion Issue – 30fps-24fps
  • EDL Conversion Issue – 30fps-24fps
    Posted by Alex Barreto on October 18, 2007 at 3:47 pm
    We have a 30fps EDL that we need to convert to 24fps for some HD graphics work. The footage was shot on a Varicam at 24fps. The offline was done at 30fps using timecode matched downconverted footage. The EDL is a CMX-3600 EDL from a Sony XPRI system. I’ve tried doing an EDL conversion using Cinema Tools but when I try using the File | Export | Converted EDL | 24 FPS from 30 FPS function, the 30fps EDL I need is not a choosable file. What would be the proper workflow for this to function? And does anything need to be done to the EDL prior to bringing it into FCP/Cinema Tools?
    Alex Barreto
    Vapor Post
    Alex Barreto replied 18 years, 10 months ago 2 Members · 5 Replies
  • Sean Oneil
    October 18, 2007 at 5:07 pm
    [Alex Barreto] “the 30fps EDL I need is not a choosable file”
    It should be. Is it named “.edl” at the end?
  • Alex Barreto
    October 18, 2007 at 5:19 pm
    It does have “.edl” at the end. I tried removing the file extension just in case but that made no difference.
  • Sean Oneil
    October 18, 2007 at 7:50 pm
    Sorry, I don’t know what the problem is. Maybe try exporting the EDL again.
  • Alex Barreto
    October 18, 2007 at 8:41 pm
    Actually I’m not able to convert ANY edl file made outside of FCP. A little more background: Several months ago I tried this very workflow on the previous version of Final Cut Studio and it worked just fine. Now I’m trying what I believe to be the same steps in Final Cut Studio 2 and it is not working. I was wondering if perhaps there was a step I was leaving out. When I open the EDL in TextEdit it looks exactly as it should look. Could there be something in a setup menu that’s missing?
    Alex Barreto
    Vapor Post
  • Alex Barreto
    October 18, 2007 at 8:45 pm
    I’ve tried importing the EDL directly into FCP and it crashes the application.
    Alex Barreto
    Vapor Post
