Activity Forums Adobe Premiere Pro edl batch capture
  • edl batch capture
    Posted by Chris on May 29, 2007 at 1:57 pm
    Batch capturing into PP using an edl from Avid (PAL) – the timecodes are completely out:
    The edl itself (any format – cmx 3600 etc) is correct when opening in wordpad – but on import the capture times change so the clips are coming in 53 frames too early.
    Also the tails of each clip are ending too soon so there are gaps in the batch-captured sequence.
    I can’t understand this at all. – Any ideas?
    E
    Chris replied 19 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
