Activity › Forums › Apple Final Cut Pro Legacy › EDL adds a frame to all Out points
Posted by Adam Donnelly on August 2, 2007 at 10:46 pmHi, I am exporting an EDL from FCP, and the Out for every shot, both in the source and master lists, are all one frame after the actual Out. Does anyone know why this is happening? Or how I can correct it?
Michael Gissing replied 19 years, 1 month ago 4 Members · 4 Replies -
Aaron Neitz
August 2, 2007 at 11:09 pmbecause OUT on an EDL refers to the frame AFTER where FCP notes it as the frame you’re currently on. Just a nomenclature difference…. and confusing as heck until I figured it out.
Mark Raudonis
August 2, 2007 at 11:24 pmEDL’s are an invention from the linear days, where the out point on the EDL represented the first frame NOT recorded. If you’ve never worked with a linear system, then this won’t make much sense to you, but if you’ve ever done an “old school” on-line, it makes complete sense.
THe other “gotcha” in this process is determining exactly what frame is represented by the “blue line” or cursor. The Avid has a second lighter line that give you a hint as to what frame is represented when you’re parked. FCP does not, and you need to understand that if you’re marking an out by typing a number, it really should be one frame later than you think.
Hope this helps.
Mark
Michael Gissing
August 2, 2007 at 11:24 pmTrap for young players. An EDL of course marks the beginning of frames so of course it displays the beginning of the frame after the out point as explained.
EDLs were designed to be read by machines so don’t expect them to look friendly to humans.
