Activity › Forums › Adobe Premiere Pro › Edius avi codecs
Edius avi codecs
Posted by Haji Man on December 13, 2010 at 2:54 pmHi!
I’m working with premiere cs5 and received avi (pal) files that were captured in Edius – there for I cant get them in premiere.what codecs do I need to download in order to import this files?
thanks much.
Jean D’alessandro replied 14 years, 5 months ago 3 Members · 5 Replies -
Haji Man
December 14, 2010 at 12:53 pmHi Brian!
I’ve mentioned that the files are PAL/SD and I will add that I’m looking for a solution (if possible) without converting ’cause there are many files.
Thanks. -
Brian Louis
December 14, 2010 at 6:00 pmWhat you need is the “Canopus Playback Codecs Pack” v303.zip
You can get it by doing a net search or going to Grass Valley’s website and registering and downloading
https://www.grassvalley.com/login?r=/support/downloads/demos
It used to be available there
If you find it on the net as part of a general codec pack, it might not be a good idea to load a general pack into your computer, sometimes they load junk you don’t need and can cause problems. -
Brian Louis
December 14, 2010 at 6:01 pmWhat you need is the “Canopus Playback Codecs Pack” v303.zip
Jean D’alessandro
April 21, 2012 at 9:29 amhow to use files edited by Edius as avi files on premiere pro cs3
