Activity Forums DaVinci Resolve Edit/XML with transitions into Resolve
  • Edit/XML with transitions into Resolve
    Posted by Kelly Armstrong on March 10, 2016 at 2:17 pm
    Hi there,
    I’m an editor and I have a question about workflow between Premiere and Resolve. I’m using a lot of push slide transitions, and cropping images which I’m keyframing into frame.
    What I’m doing is very similar to this reference video: https://vimeo.com/25049692
    Will these transitions be read by Resolve? Or do I need to take them off and re-apply them in the Conform?
    Kelly
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Glenn Sakatch replied 9 years, 8 months ago 6 Members · 6 Replies
  • Joseph Owens
    March 11, 2016 at 2:53 am
    Not all transitions are translated exactly between NLEs and Resolve and you should expect some discrepancies. The other issue with cropping is that you will run into absolute value mismatch if there are any format multipliers — resolution or aspect ratio changes.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Marc Wielage
    March 11, 2016 at 6:41 am
    I would advise doing a short (1 minute or less) test and see how the effects translate. In some cases, the latest versions will work OK. Be aware that repositions are often affected by source resolution, so if you have HD proxies of a 4K project, and then bring the 4K media into Resolve, the repos/slides/whatever may not work.
  • Kelly Armstrong
    March 11, 2016 at 9:11 am
    Hi Marc,
    Thanks for your speedy reply. I’ve added the transitions to the RAW 2K footage so ill try bringing it into Resolve and see if they work.
    Kelly
  • David Patterson
    December 31, 2016 at 10:05 pm
    Did you find a way to color grade clips in Resolve and retain the transitions or extra frames needed for transitions in Premiere?
    I wouldn’t mind having to apply transitions in Premiere after grading, but transitions need additional frame “handles”. How will these be created when exporting graded clips from Resolve?
  • Shane Ross
    January 1, 2017 at 2:55 am
    This is why I ask clients for a full res, textless quicktime export. So I can use that in places where custom transitions occur.
    Shane
    Little Frog Post
  • Glenn Sakatch
    January 2, 2017 at 4:51 pm
    If you are round tripping with consolidated media, you need to add handles in the edit programs list creation.
    turn on the view handles function when you start your color session.
    Export with handles in the delivery page.
    Glenn
