Activity › Forums › Apple Final Cut Pro Legacy › EditToTape-MBP to DVCAM (Sony DS-45)
  • EditToTape-MBP to DVCAM (Sony DS-45)
    Posted by Eric Baron on October 31, 2008 at 1:51 am
    Need help mastering to DVCAM. I know that I can’t generate TC in DV over firewire, but how can I master to tape without I/O card/box? FCP doesn’t recognize TC striped onto my tape. I’m trying to go firewire DV straight into deck from MBP. Every time I try it aborts and breaks TC.
    If I striped/timecoded the tape from a different video source, does it matter? Been in tapeless mode for the last few years, don’t miss going out to tape!
    Thanks in advance for your responses!
    Eric
    Eric Baron replied 17 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Bouncing Account needs new email address
    October 31, 2008 at 4:09 am
    A Sony DSR-45 doesn’t “edit” does it?
    It can only “crash record” (which with DV usually looks petty clean, however.)
    To control a record deck to match-up to a Timecode pre-roll you must use the RS422 for deck control and not FireWire.
  • Eric Baron
    October 31, 2008 at 4:12 am
    Don’t know…but if that’s the case, I need an I/O box to output to this tape deck. They told me it can be controlled through firewire but I don’t know.
    Eric
  • Kevin Monahan
    October 31, 2008 at 6:15 am
    Just pre-stripe the tape with TC and then use Edit to Tape via FireWire. The DSR-45 will do that.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Eric Baron
    October 31, 2008 at 5:06 pm
    thanks Kevin,
    when I try to assemble edit, the tape cues up properly, then hard cuts into the TC and stops, with “unable to locate requested timecode. Please verify that tape is timecoded correctly. I striped/coded the tape with a composite reference signal from another system, could that be my problem? Thanks in advance…
    Eric
  • Alan Okey
    October 31, 2008 at 8:56 pm
    I might be mistaken, but I seem to remember the DSR-45 only being capable of frame-accurate insert editing when using RS422 deck control.
  • Paul Dickin
    October 31, 2008 at 9:18 pm
    Hi
    My lesser-spec DSR decks do that IF I’ve forgotten to change the timecode setting back to Internal/Regen after doing the stripe.
  • Eric Baron
    October 31, 2008 at 10:52 pm
    thanks a million, that’s exactly what it was!
    Love this forum!
    Eric
