Activity Forums VEGAS Pro editor & plugins
  • editor & plugins
    Posted by Ken Karn on November 6, 2007 at 12:08 pm
    Hi all,
    I reinstalled Vegas 7. Sound Forge 8 as well.
    When I try to open SF8 (even from within Vegas)
    it scans plugins and hangs “Installation folder not found. Please select a folder now.”.
    SF8 Never opens; so how do I select a new folder?
    Ken
    Larry Brewer replied 18 years, 10 months ago 2 Members · 1 Reply
  • Larry Brewer
    November 6, 2007 at 9:03 pm
    This may or may not be related to your current problem.
    It has been advised to always use default folders when installing Vegas products. ie… C:program files/sony/vegas pro 8.
    While the option is there to choose a different install location the problems of finding plugins, and such exists.
    Did you use the default install location when you did the initial setups? If not, maybe that is an issue.
    Hope this helps.
