Activity › Forums › Apple Final Cut Pro Legacy › editing xdcam standard def in fcp 5.1
  • editing xdcam standard def in fcp 5.1
    Posted by Phil Holt on March 22, 2009 at 9:56 am
    hi everyone. long time reader first time poster. 🙂 please help!!!!
    im running a duel 2ghz g5 powermac with fcp 5.1 w/ a lowly 1gb of ram (planning to increase) i have used the sony xdcam transfer to import mxf files into fcp, however on my timeline they all require rendering!!!!
    WWWHHHYYYYY OOOO WWWHHHHYYYYY!!
    this is the first time i have used a non tape based format and am confused as hell. i have looked around the net but have not found anything spacific to my problem. It seems from sony literature that it should be fine and not require editing.
    is there something ive missed? i’ve tryed to do a “mixdown” type fucntion to convert them into another file but alas.
    please help a little ol editor down the bottom of the world.
    thanks in advance.
    Phil Holt replied 17 years, 6 months ago 3 Members · 3 Replies
  • Rafael Amador
    March 22, 2009 at 2:08 pm
    Hi phil,
    I think that in this thread you have a lot of interesting information:
    https://forums.creativecow.net/thread/142/863363#863363
    Cheers,
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Andy Mees
    March 22, 2009 at 2:30 pm
    Phil
    You have a simple source/sequence format mismatch. You just need to set your sequence timeline to the same format as the source footage.
    You note that you’re working with FCP5 so this format matching won’t happen automatically, you have to do it for yourself.
    You also note that you’re shooting a standard def XDCAM format so that means either DVCAM or IMX 30, 40 or 50. You probably already know which format it is, if so, simply go to your Easy Setup menu and select that format from the list and click OK. Then create a New Sequence and test to see if you still need to render.
    If you don’t know the format then a quick trick is to select one of your source clips in the Browser and choose Modify menu > Make Multiclip Sequence. A sequence will be created for you automagically that matches that source clip format.
    Failing that, just post back with the source clip Item Properties (select a clip and press Cmd 9) and also with the sequence Item Properties (select a sequence and press Cmd 9, or select the Timeline window and press Cmd- Zero)
    Best
    Andy
  • Phil Holt
    March 22, 2009 at 7:14 pm
    hi all. thanks so much for your replys. this eems to have done the trick.
    the result is editing with a green preview render over the footage.
    if i get more ram, will this disappear/turn to light blue?
    thanks again for your help.
