Activity › Forums › Adobe After Effects › editing with sound
editing with sound
Posted by Alex Messina on May 21, 2008 at 11:22 pmwhen i edit my videos in after effects there is no sound is there a way to change this
Paul Hennell replied 18 years, 3 months ago 2 Members · 1 Reply -
1 Reply
Paul Hennell
May 22, 2008 at 1:09 pmI’m assuming you mean while previewing content, rather then when exporting it, its a common issue, becuause you can’t just hit space to play sound and video in AE.
To hear sound you have to do a ram preview, so it can play it at the full speed with pre-rendered video. (If a ram preview doesn’t play the sound check it’s not muted in the layer, and that Comp> Preview>Audio is ticked.)
You can also just play the audio from the current position by pressing the number pad . key, which if you display the waveform in the audio track layer, means you can have a fairly good idea what you’re doing. (If you have specific points to edit to, drop down the audio waveform, play the audio with the [numpad] . key, and mark the key audio sections with the [numpad] * key to aid synchronising bits.
Check out the help guide for more on ram preview settings and working with audio.
