Activity › Forums › Adobe Premiere Pro › Editing with Premiere on a Laptop
Posted by Terry Kampowski on June 29, 2008 at 2:01 pmDoes anyone edit with Premiere on a laptop?
If yes, then what are your experiences and what have you learned?Warren Morningstar replied 18 years, 2 months ago 7 Members · 7 Replies -
Vince Becquiot
June 29, 2008 at 6:23 pmIt depends on what you are trying to edit. If you want to do it the right way, you really won’t be that mobile. You’ll probably need a machine with 2 drives (Forget battery life), and an external SATA RAID for fast access on long projects, and/or back up.
Laptop displays are also the biggest offenders on calibration. It will work if you are on the road, but in most cases you’ll need at least an external monitor at some point in your final edit.
Most current laptops will handle SD very well, not HD, or at least not without constant rendering.
Vince
Philip Merten
June 30, 2008 at 3:43 amI just installed Premiere Pro CS3 on my laptop that runs Vista and it works perfectly; although I plan to limit its use for news and when I need to edit in the field for whatever reason.
Mike Cohen
June 30, 2008 at 7:10 pmI run 2.0 on a XP Pro Core 2 Duo Dell with 2 gigs ram and internal 7200rpm 120 gig drive, and external USB SATA drive.
Warren Morningstar
June 30, 2008 at 9:02 pmI’m running CS2 on a ThinkPad T42 (1.60 GHZ Pentium M – single core) with a 2nd hard drive in the megamedia bay and 3 gigs of RAM. Works just fine with SD (DV) video. I’ve cut a lot of things in the field. It will handled HDV (mpeg) timelines if they are simple and you have patience. Tends to choke if you try to use Cineform Aspect intermediate codec.
Tim Kolb
June 30, 2008 at 10:21 pm[Warren Morningstar] “I’ve cut a lot of things in the field. It will handled HDV (mpeg) timelines if they are simple and you have patience. Tends to choke if you try to use Cineform Aspect intermediate codec.”
That’s interesting…typically it should be the other way around. A much weaker processor will push CineForm around than HDV…HDV’s MPEG chores are much more processor-intense than CineForm.
I edit CineForm HD fairly regularly, including 2K on a Dell M90 (not a small machine by any means), but I’ve edited CineForm Aspect 1080 stuff on a single core 2.8 GHz laptop with an external FireWire drive…2 streams with effects…no problem. That machine could not handle HDV native under any circumstances…
TimK,
Director, Consultant
Kolb Productions,CPO, Digieffects
Dan Asselin
July 1, 2008 at 1:15 amI edit for all kinds of clients on Premiere Pro on my laptop. Now most of what I am working with is DV but I find that it is not really necessary to have an extremely quick laptop either. That’s becaue I edit with the client but RENDER back at the office using an external drive. If you don’t have to deliver a finished product right away this works like a charm and really impresses clients.
Warren Morningstar
July 1, 2008 at 3:02 pmIt may be that my second hard drive doesn’t spit out data fast enough for Cineform. Or there may be some other variable in there. I haven’t tried very hard to figure out why because it’s not critical to what I do. If I have to edit on the laptop, it’s usually for something that needs to be posted to the Web quickly. So I downconvert the video in the camera and bring it in as DV. And my laptop, which is now getting a bit long in the tooth, handles that just fine.
