Activity Forums Avid Media Composer Editing with oversized pictures
  • Editing with oversized pictures
    Posted by Craig Lee on June 27, 2006 at 9:20 pm
    I am editing a project on AVID Xpress Pro HD 5.2 that uses some pictures. Is there a way to bring them into AVID and keep their size larger so I can use them with the pip to zoom into and out of the picture with out becoming pixilated? Thanks
    Jon Zanone replied 20 years, 3 months ago 3 Members · 2 Replies
  • Anonymous
    June 28, 2006 at 2:25 am
    I beleive if you change you import setting to “Maintain, Square” that should do the trick.
  • Jon Zanone
    June 28, 2006 at 11:25 am
    Look at using the ‘pan & zoom’ effect, if your going for that ‘Ken Burns’ effect. Add some filler (it could be anything, like a submaster FX, a clip of video), add the P&Z FX. Go into the FX edit mode, and click on the little box in the top left hand corner. A dialog will open asking you to select your photo. Play!
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
