Activity Forums Apple Final Cut Pro Legacy Editing with different frame rates
  • Editing with different frame rates
    Posted by Kelly Armstrong on January 6, 2014 at 2:27 pm
    Hi there,
    I’m editing a music video and I have two different frame rates to work with- 25FPS & 50FPS.
    Most of the 50fps is just slow motion dancing which I’ll cut away to, although theres a few lip syncs with the 50fps.
    I’d like to set my edit to 25FPS, but how will the 50FPS footage work with that?
    Kelly
    Kelly Armstrong replied 12 years, 7 months ago 3 Members · 5 Replies
  • Kelly Armstrong
    January 6, 2014 at 5:04 pm
    Hi Dave,
    Thanks for getting back to me so quickly. I’ve never used Cinema Tools before- if I transcode the 50FPS footage to 25, won’t it lose its slow motion effect?
    Kelly
  • Shane Ross
    January 6, 2014 at 5:30 pm
    Tutorial on how to use Cinema Tools to slow motion footage:
    https://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
    Shane
    Little Frog Post
  • Kelly Armstrong
    January 6, 2014 at 5:32 pm
    I haven’t conformed before, so thank you for clarifying that for me.
    Is there an alternative software to Cinema Tools? Ours is having problems at the moment.
  • John Kaley
    January 6, 2014 at 5:41 pm
    Quick note, Cinema Tools only works on full frame media like ProRes. XDCam, h.264, ect will not work in Cinema Tools. If you must conform and transcode, Compressor can do this in one step.
  • Kelly Armstrong
    January 6, 2014 at 6:09 pm
    Great,
    Thanks so much for the advise!
